-   -   No heat 2002 sonata, ? relay, where is it (https://www.hyundaiforum.com/forum/general-tech-help-5/no-heat-2002-sonata-relay-where-5051/)
dsrming13 Nov 13, 2008 10:45 AM
i recently changed my battery and since then i have no heat/ a/c. I have check al fuses. Is there a relay i should check
igotnothin Nov 25, 2008 08:49 AM
RE: No heat 2002 sonata, ? relay, where is it
If you just changed your batery, i would check the fuses under the hood if you have not done so...
There are relays, but i doubt you blew both of the relays for the blower.. There is typicaly one for the lower fan settings, and one for the highest fan setting.. Id check the fuses under the hood...
