P0171 code
Old Sep 6, 2007 | 09:35 PM
2001sonata's Avatar
Default P0171 code
I have a 2001 Sonata with the 2.4 4 cyl, auto, it has been giving off an engine code of P 0171, running lean, Any ideas what needs to be replaced or repaired? The car idles very rough when first started and sometimes has a noticeable miss at around 35-40 mph
thanks
Old Sep 14, 2007 | 08:01 PM
lighthouse1's Avatar
Default RE: P0171 code
check the maf sensor (mass air flow) located in the fresh air intake tube between filter and trottle body -they have problem with them and will set lean mixture trouble codes
Old Oct 3, 2007 | 09:04 PM
Freddie's Avatar
Your PVC hose from the valve cover to the intake is split.
shawnboy
Sep 22, 2012 10:41 AM
capt1992
Apr 5, 2011 12:46 PM
sonata00
Feb 10, 2011 10:48 AM
mikecorky
Oct 25, 2010 07:18 PM
blackbox19
Aug 6, 2010 09:59 PM
