santa fe 2005 no arranca
Old Jan 8, 2021 | 05:12 PM
Pedro Vicente Suarez Olivera's Avatar
Arrow santa fe 2005 no arranca
Que hacer mi hyundai santa fe 2005 se volo el fusible de 10 A DEL ECU 3,le puse otro e hizo lo mismo,no arranca,todos los rele estan ok,q hacer en ese caso...
Old Jan 8, 2021 | 11:01 PM
avisitor's Avatar
What is making your 2005 Santa Fe blow the ECU#3 fuse? Replace the fuse and it blows. No start. Relays are ok. What is causing this?
You have a wiring issue. Short circuit. Put a test light across the terminals of the socket of the fuse.
The short will make it light up. Then go about looking at the wiring harness.
Look for any place that rubs against metal, plastic. Heat, vibration.
If you ever disconnected something then check the pins of the connector.
Wriggle wires to see if there is a change in the light from the test light
Good luck hunting
Andrew Gormley
Jan 2, 2012 04:42 AM
Mariah27
Mar 4, 2011 07:32 PM
yahoo.eu
Aug 14, 2007 07:25 PM
yahoo.eu
Aug 2, 2007 08:15 AM
tfq48
Jun 17, 2005 01:51 AM
