-   -   Search: Wiring diagram for buzzer (H95710 (957103L010)) (https://www.hyundaiforum.com/forum/general-tech-help-5/search-wiring-diagram-buzzer-h95710-957103l010-14165/)
mhety82 Jan 20, 2014 05:39 PM
Hi!
I've got a question.
I want to upgrade my keyless entry with the "answering function" (beep at locking and unlocking the doors) because unfortunately in Germany it isn't standard.
I want to order the buzzer (H95710 (957103L010)) and connect it to the turn light connection signal on my remote door lock control unit inside the car so if the turn lights flash during locking the buzzer will beep the same time and additionally in that way it will not beep if you turn on the turn lights or during drive lock.
For that I need a US wiring diagram of the buzzer (I think there should be 2 pins: + and ground) to see which of these two pins is the ground pin and which is the plus pin and has to be connected to the turn light signal of the remote door lock control unit.
It doesn't matter if the wiring diagram is of an Hyundai Tucson or another Hyundai.
My concern is to figure out which of these two pins is the ground pin and which is the plus pin.
Just as an additional: Maybe you can tell me how the plug of the buzzer is look like and if I can order it separately (part no.?)?!
I mean the plug that contains the 2 wires (+ and ground) and is plugged on the buzzer.
I hope I have written half-way understandable.
Thank you in advance for your help!
Best regards from Germany!
Martin
