Shift Knob Replacement 04 Tiburon GT
Old Oct 8, 2008 | 03:20 PM
azkevin724's Avatar
Default Shift **** Replacement 04 Tiburon GT
Hi,
I have an '04 Tiburon GT 6 speed and the top of **** that shows the gears came off. There is a small chip out of the black handle below. How is the handlereplaced and is it difficult to do?
Thanks
Old Oct 8, 2008 | 10:33 PM
ken99's Avatar
Default RE: Shift **** Replacement 04 Tiburon GT
I have an '04 Tiburon GT 6 speed and the top of **** that shows the gears came off. There is a small chip out of the black handle below. How is the handle replaced and is it difficult to do?
From http://www.hmaservice.com/:
1.Remove the shift ****.[/align]
2.Remove the spring and the cap (for 6-speed M/T).[/align]
3.Remove the skirt (for 6-speed M/T).[/align]
4.Remove the console upper cover.[/align]
5.Remove the console assembly.[/align]
6.Remove the shift cable clip.[/align]
7.Remove the select cable clip.[/align]
8.Remove the snap pin of the select cable.[/align]
9.Remove the shift cable.[/align]
10.Remove the shift lever assembly.[/align]
CAUTION: For 6-speed M/T, push the plate shaft outward with a driver or equivalent through the hole in the shift lever bracket to remove it.[/align]
trojan
Sep 28, 2009 03:53 PM
nashjared1
Oct 10, 2007 04:09 PM
seiken
Jan 26, 2007 05:55 PM
martianiv
Jul 3, 2006 08:49 PM
02grayelantra
Aug 9, 2005 10:38 PM
