Slow Fuel Fill Problem Diagnosis
Old Sep 7, 2011 | 02:48 PM
  #21
MacSparky's Avatar
Hi, I'm new to this site as of this morning. My wife's '01 Sonata is having this type of problem, with one added. She starts filling the tank, and then the fuel sprays back out.
Old Sep 7, 2011 | 02:56 PM
  #22
MacSparky's Avatar
I forgot to ask, does the car need to be up on ramps/jack stands to get to the ORVR?
Old Sep 20, 2011 | 02:21 PM
  #23
gwaddis's Avatar
Default Fuel fill problem
Like the info, my problem is when I fill up it shutoff the the engine floods out and is hard to start. I have a 2003 Sonata with 234000mile and drive 120miles a day in LA Calif. Love the car but this is starting to bug me.
Old Nov 3, 2011 | 01:37 AM
  #24
edcars954's Avatar
my accent has problems with gas filling and it smells like gas when i open the windows. but if i turn my ac on it doesnt smell. maybe alil. is it still problems with the cannister?
Old Nov 3, 2011 | 10:26 AM
  #25
ritchep's Avatar
Hey edcars954, it sure sounds like a canister problem. My Accent did the same thing. You may want to have a mechanic look at it though. Keep in mind the fuel pump for your Accent sits underneath the back seat. It sits in a well with a weep hole to allow leaking gas to fall out, but it could still smell if for some reason it develops a leak. Has it been doing it for long?
Old Nov 5, 2011 | 12:39 AM
  #26
edcars954's Avatar
ritchep,
yeah. its been a few years since having that filling problem. and this year i noticed the gas smell. i dont smell it when the windows are closed. but when i open my windows thats when i can smell it. im planning to drive from houston to miami in a few weeks. will it be safe? hahaha. and how much do you think this will cost me? how did you fix it?
thanks
Old Nov 5, 2011 | 02:02 PM
  #27
ritchep's Avatar
ritchep,
thanks
Hey edcars, I never did totally fix my problem. A new charcoal canister system installed by the dealer is $500+ dollars. I just can't bring myself to spend that kind of $$ on a 9 year old car with 169,000 miles on it. There's a 3/4" hose that runs from the canister to the fill pipe, and I have removed and dumped out charcoal pellets several times, which has totally eliminated my slow fill problem. I do get an intermittent "check engine" light, and the OBD tester says it's an emissions vent problem ... probably due to me dorking around with the hose. Either way, I've driven mine 50,000+ miles with no ill effect. But then again, I'm not an expert! Good luck friend.
Old Nov 5, 2011 | 07:13 PM
  #28
edcars954's Avatar
thanks. do you smell gas too in your car?
Old Nov 6, 2011 | 05:03 PM
  #29
ritchep's Avatar
I get an occasional whiff of gas every now and then, but for the most part I don't smell gas.
Old Dec 1, 2011 | 09:47 PM
  #30
Skwurl4's Avatar
Can any body tell me were the vapor vent valve is my 00 sonata is throwing up the evap system light and I can't afford to have the mechanic take his time trying to do a smoke test and funding the leak. I did a visual inspection of the lines they all look fine and no rust build up anywere if it was my charcoal canister it would throw up a different code but its nit so I'm pretty its the bait bent native but I can't find out in your diagram
