Sluggish Shift on a Sonata
Hey guys, any help on this is appreciated:
I revently got an 01 Sonata automatic, and about two months in Ive noticed its shifting bad- it locks up at 5x rpms until I take my foot off the pedal, than it switches to the next gear. Also, on the third gear it jumps awkwardly to 4-5x rpms the moment it switches, almost like its slipping and going right back to second. I had a similar problem on my focus and all that needed was an oil change, but this seems worse. Any ideas? Thanks Again |
RE: Sluggish Shift on a Sonata
Have the trans fluid serviced first and go from there.
Contaminated fluid can cause the symptons you are describing. |
Is your check engine light coming on?
Yea its popped on a few times for a couple minutes
Get that checked out first- could be a Throttle Position Sensor or an Output Speed Sensor. What you DON'T want to see is DTC P0734...........that's badness.
Got it checked yesterday-they said no check engine light came on for them and the diagnostic revealed no error codes.
So it seems the trans fluid is the culprit.right? |
Maybe..... don't get your hopes up, though. You might try getting a priest to bless the new transmission fluid before you put it in.
Good luck!! |
How many miles are on the car?
If more than 60k... its time for a trans service without a doubt. |
