sonata 2003 2.7l V6 wheel no more fit
Hi,
I changed the wheel hub assembly if the rear left wheel. The part dealer sold me is the same as shown (number)on all sites. The part is not exactally the same as the one which was on place. The old one shows a plate of mm more. All turns well, the tire in place, all turns well but when the nut are tighted, the wheel stop turning ; it blocks. I really can not see what could be the problem. Can someone help ? Thank you |
RE: sonata 2003 2.7l V6 wheel no more fit
[align=left]Obviously, it is NOT the correct part. Take the part back to the dealer, along with the original part. Maybe he can match it up with the correct one. Where did you get the "correct" part number? What number do you have? Where did you buy it?
