surging
I have a 2003 Santa Fe it is having a surging problem. You drive along and it looses power then surges. You can be in park or neutral and rev the engine and it will drop back to 1200 rpms or there abouts and then back to what ever you reved it to. Any help would be appreciated. Also if you idle its fine. but if I slowly rev to 2000 rpms it goes to 4000 and then back to 1500 or so.
RE: surging
Really sounds like an EGR problem, possibly a blocked EGR valve.
RE: surging
Thanks, added a little more about the problem. Its just odd at full throttle no problem. Thanks again, Frank
RE: surging
OK, after you further described it, really sounds like a fuel issue.
Do you know what your fuel pressure is? |
RE: surging
Haven't checked fuel pressure but will today and let you know. Thanks
