ticking sound in my 06 Azera
I have 65k miles on my Azera. Lately, when I start it up, and its cold, it makes a ticking sound when in 1st gear. Does not seem to lose power.....just an annoying sound. Also, when I start the car engine, it idols very loud and at high RPM's for a brief time......and then it comes back to a proper idol. Any suggestions on how to eliminate these issues.
Thanks!! |
RE: ticking sound in my 06 Azera
Could be lots of things. First of all, it's cold. If it only does it in first gear, then sounds like a trans problem. Did you do the scheduled maintainence trans flush?
I just had a trans flush @ Jiffy Lube. To be more specific, It sounds like when as a kid, when we would put baseball cards clipped on to our bicycle so it would make that noise in the spokes.......when I get up to about 25 mph.....the sound goes away......only can hear it at very slow speeds.
Oh, Jiffy lube. Yeah, that might be the problem. Jiffy lube will do a flush with Dextron III, which is supposed to be universal. But Hyundai spec fluid is what is specified...Diamond ATF SP ??? or SK ATF SP ???. Some people say it's real bad to use Dextron III, and I think it voids the warranty. Here's the spec sheet and Technical Service Bullitin:
2006 > G 3.8 V6 DOHC > Automatic Transaxle System http://www.hmaservice.com/viewer/img/email_icon.gif http://www.hmaservice.com/viewer/img/print_icon.gif SPECIFICATIONSEngine type[/align]??-3.8[/align]Transaxle type[/align]A5HF1-2[/align]Gear ratio[/align]1ST[/align]3.840[/align]2ND[/align]2.092[/align]3RD[/align]1.440[/align]4TH[/align]1.048[/align]5TH[/align]0.728[/align]REV.[/align]3.859[/align]Final gear ratio[/align]3.333[/align]T/M oil capacity(???)???[/align]10.9[/align]??? The quantity in the chart above is for the reference. The actual filling quantity of the automatic transaxle fluid must be set according to 'INSPECTION' or 'REPLACEMENT' procesure of the automatic transaxle fluid.[/align]Recommended transaxle oil[/align]Diamond ATF SP ??? or SK ATF SP ???[/align]Check & Replenishment[/align]Every one year or every 24,000km[/align]Replacement[/align]Private use[/align]Normal use[/align]No service required[/align]Severe use(???)[/align]Every 48,000km[/align]Business use[/align]??? Severe use(marked '???') is defined as:[/align]1.Driving on rough road(bumpy road, gravel road, snowy road, unpaved road etc.).[/align]2.Driving on mountain road, ascent/descent.[/align]3.Repetition of short distance driving.[/align]4.More than 50% operation in heavy city traffic during hot weather above 32??C(89.6??F).[/align]5.Police car, Taxi, Commercial type operation or trailer towing, etc. Page 1 of 2 Technical Service Bulletin Subject Group Number Date Model CIRCULATE TO: [ ] GENERAL MANAGER [X] SERVICE ADVISOR [X] SERVICE MANAGER [X] WARRANTY MGR [ ] SALES MANAGER [X] PARTS MANAGER [X] TECHNICIAN TRANSAXLE 06-40-010 JUNE, 2006 2006 AZERA & SONATA 3.3L NOISE FROM BELLHOUSING DESCRIPTION: Some 2006 Azera and Sonata 3.3L vehicles may exhibit a rattling or growling noise in the bellhousing area of the automatic transaxle. Please follow the repair procedure shown below to diagnosis this condition. NOTE: There are no performance issues associated with this condition. REPAIR PROCEDURE: 1. Use a stethoscope to determine the location of the noise. If the noise originates from the bellhousing area and the vehicle is produced prior to May 04, 2006, remove the transaxle. 2. Check if the ring gear can be moved relative to the hub. If so, replace the C.P.S. wheel plate assembly, P/N 23200-3C130. VEHICLES AFFECTED: ??? 2006 Azera produced prior to May 04, 2006 ??? 2006 Sonata produced prior to May 04, 2006 [/align] [/align] findme('); findme('); findme('); |
Is this service (wheel plate replacement) covered under warranty?
Sounds like it, if you are the original owner. Supposed to be 10 yr/100k miles. Don't tell them you went to Jiffy lube.
OK......sounds good.....thanks a bunch!
BTW.....where did you come up with this info?? |
Join the hmaservice.com website. It's the official Hyundai service site.
ok....thanks
Which engine in the car?
