Timing belt diagram for 2.4 DOHC
Hi Guys , looking for a diagram for a 04 2.4 dohc timimg belt , need to replace one an so far haven't found a book on it ,My dealer isn't any help ,so still looking . thanks for any advice, Slimone
RE: Timing belt diagram for 2.4 DOHC
timing belt diagram? what exactly are you doing? there arent many ways that a timing belt can be routed.
Hi, Well just looking for a diagram that will show all the timing marks on gears an oil pump drive, will be changeing it very soon . Just looking to pevent haveing any problems doing it . Thanks Slimone
Hi Guys , A friend of mind has alldata and he emailed the diagram to me , so that takes care of that , thanks anyway Slimone
Hi Slimone, any chance of emailing that diagram to me? I have the same problem. Thru here or. warbow7773@optusnet.com.au Cheers
Hi Patrick, it is obvious what Slimone is asking. If you can help with a diagram of the timing belt setup showing timing marks and procedure to change the belt, then do so, instead of asking silly questions, I am only new on this forum and after posting various pleas for assistance re timing belt change procedure and diagrams showing timing marks for the 1.8 litre dohc 16 valve motor in the 1994 Hyundai and seeing replies like yours or hundreds of hits on different subjects with no useful help forthcoming have come to the conclusion that this forum is next to totally useless. Even less than useless when you see the smartass answers that some members post. Cheers and Sayonara, Adios, Hasta La Vista
