trouble code P0301 any help?
I have been sorting thru posts and replies in this forum for over 3 hrs now and cannot seem to find anything on this trouble code
P0301 I know it can be one of the following things: Ignition System Fault ( already changed the plugs and wires ) Vacuum leak (checked, nothing found) Fuel Injector Fault (any help on how to check this) High or Low Fuel Pressure (trying to avoid going there) Vehicle: 2000 Hyundai Elantra 2.0 Manual Trans. 130,000 miles Any help would be great |
RE: trouble code P0301 any help?
Hi Member:
The code you put in there can be caused by multiple cylinder misfireing from cylinder #1...Check for faulty spark plugs, wires and coil, also check for vacume leaks and even fuel injector problem...have a fuel pressure check done by someone who knows what theyre doing..Hop this Helps you out: WheelBroker1 [sm=americanasmiley.gif] |
If you had a bad injector, your car would be running very poorly.
When was the last fuel filter change? Fuel pressure drops are 9/10 a clogged filter or the fuelpump failing. |
po301 - is missfire #1 cycliinder most likely on a elantra its plug wire - or plug /coil
I would say most likely is a coil pack problem.
ORIGINAL: Doohickie I would say most likely is a coil pack problem. |
