Trouble with Engine Code P0300 P0301 P0304
I have replaced coils, wires, spark plugs and even timing belt. I even did a compression test and the compression is right around 160 psi. My next option is to replace the Mass Air Flow. I don't know what else to do with this car???? Any help will be good!
RE: Trouble with Engine Code P0300 P0301 P0304
Are there any driveability issues, or is it just the codes? If you just changed that stuff out, I think it might take a while for the codes to go away.
http://www.hmaservice.com/images/note.gif [/align]http://www.hmaservice.com/images/noteover.gifhttp://www.hmaservice.com/images/note.gif[/align][/align] http://www.hmaservice.com/images/trans.gif Technical Service Bulletin Group 36 - Engine Electrical Number 99-36-014 Subject Date MISFIRE CODE DIAGNOSIS 09-1999 Model Accent1996-2000, Elantra1996-2000, Sonata1996-2000 and Tiburon1997-2000 [/align] Misfire code diagnosis[/align] This Technical Service Bulletin supersedes 97-90-012. Please discard the old TSB and replace it with this new one. [/align] A Guide To Repairing Misfire Codes [/align] Please read through this entire bulletin before using any portion of this repair guide. All terms, components and specific procedures are described in the main body of this TSB.[/align][/align] On the 1st repair attempt:[/align] Record misfire codes. Choose the most appropriate category from the four (4) selections below:[/align] One cylinder has a misfire code (see procedure A) [/ol] Paired misfire codes as described below (see procedure B) Cylinders 1 and 4 or cylinders 2 and 3 (4 cylinder engines)[/align] Cylinders 1 and 4 or cylinders 2 and 5, or cylinders 3 and 6 (V6 engines)[/align][/ul][/ol] Multiple cylinders have misfire codes, and/or there is a random misfire code (see procedure C) [/ol] Misfire code (one or more) occurs only on cold startup (see procedure D) [/ol][/align] Procedure A[/align] (One cylinder misfire code)[/align] Mist spark plug wires and check for arcing. [/ol] Remove spark plugs and check for evidence of carbon tracking. [/ol] Perform cylinder leakage (leak-down) test. If leakage is less than 10%, continue to step 4.[/align][/ol] If leakage is 10% or greater, remove the head to perform valve job. (See specifics in cylinder head section). [/align][/ol][/ol] Replace spark plugs. Lightly apply dielectric grease to the spark plug wire tip/boot base. [/ol] If misfire is in cylinder #4 (P0304) on Elantra or Tiburon, loosen and retorque the M12 cylinder head bolts to 26 ft-lbs + 60° angle + 60° angle. [/ol] In the misfiring cylinder, swap injector with another cylinder. [/ol][/align] Procedure B[/align] (Two misfire codes that are coil paired; Cylinders 1 and 4 or cylinders 2 and 3 (4 cylinder engines); Cylinders 1 and 4 or cylinders 2 and 5, or cylinders 3 and 6 (V6 engines))[/align] Mist spark plug wires and check for arcing. [/ol] Remove plugs and check for evidence of carbon tracking. [/ol] Perform cylinder leakage (leak-down) test. [/ol] If leakage is less than 10%, continue to step 4. [/ol] If leakage is 10% or greater, remove the head to perform valve job. (See specifics in cylinder head section). [/ol] Replace the coil. [/ol][/align] Procedure C[/align] (Multiple cylinders misfire codes, and/or a random misfire code)[/align] Check LT (Long Term) fuel trim. If over 10%, check fuel pressure. [/ol] Check AFS calibration against known good value. [/ol] Check for proper operation of EGR and purge control valve. [/ol] Mist spark wires and check for arcing. [/ol] Remove spark plugs and check for evidence of carbon tracking. [/ol] Perform cylinder leakage (leak-down) test. If leakage is less than 10%, continue to step 7.[/align][/ol] If leakage is 10% or greater, remove the head to perform valve job. (See specifics in cylinder head section).[/align][/ol][/ol] Check fuel sample from the inlet (bottom side) of the filter to check for the presence of water or contamination. [/ol] Check intake air supply for evidence of oil in the air cleaner or on the AFS. [/ol] Tweak pins on |
