troubLes starting cold
I have a 2000 accent when you first start up the car it does not want to start it will but will shake and then die it will then run without stalling. Any suggestionm Thank You
Check to see if there are any codes in the computer first.
Got a code 1128 I think can't remember but it was about fuel trim to lean.g
Well, that's where I'd start looking.
That code I thought is usually related to emission stuff.
