Vibrating
Hello.
I have a issue with something under the dashboard is vibrating whilst driving. I have found out that it is more audiable if I travel at 50km/h but it can start at anytime like when I just start the engine and start moving. Things I have tried: Made sure all tires are pumped up to the max and checked for wear (which there is none). Removed all loose objects such as paper and coins from the front of the car. James I30 crdi diesel 2010 |
When something is vibrating "under the dash" it is probably something loose under the dash. You may put your contortionist skills to use and lay on your back into the footwell. Use a head light and look up there, touch everything you can reach and push, wiggle, pull to find anything loose.
You could also remove the lower panels of the dash etc. Good luck! |
Just to update .. The issue seems to have disappeared, not sure why.
