water pump
Wondering how much to install a water pump on a 1996 Hyundai Sonata 2.0L 16V[:@][:@][:@][:@][:@][:@][:@][:@][:@][:@][:@][:@]
RE: water pump
It's a sort of a job that is unwise to JUST do the water pump. Normally, since you have to remove the same parts, you also do the timing belt at the same time. So probably, it's similar to a timing belt job, which is $200 to $1000 depending on where you take it and what parts you replace. Why do you think you need a water pump?
