Water temp sensor ac
Old 07-20-2019, 04:13 PM
Raiderf's Avatar
Default Water temp sensor ac
Looking for the water temperature sensor for the ac system on a 2005 Santa Fe . Have tested the ac thermistor , triple switch , relay, Freon levels . Everything tests good, ac stops working after 15 mins of run time. Trying to locate the water temp senor to test it. Thanks
Old 07-20-2019, 06:44 PM
tw2005's Avatar
I'm a little confused on what a water temp sensor is or has to do with the AC? I can see thermistor inside, triple pressure switch, Air Quality Sensor,Ambient temp sensor(front of Rad),In car sensor, and a thermal fuse in the clutch coil
Old 07-21-2019, 10:12 PM
avisitor's Avatar
If it works for a little while then stops working then possible low on refrigerant??
Or could be expansion valve not working??
Just guessing
Alexjordan22
08-22-2019 05:40 AM
Chris M.
05-15-2018 07:32 AM
Chris M.
05-13-2018 10:46 PM
Ahmed Mohammed
09-30-2015 04:24 PM
mikeyhd
09-22-2006 01:06 PM
Quick Reply: Water temp sensor ac
