Where is the ETACS on a 2005 Hyundai Elantra?
Where is the ETACS on a 2005 Hyundai Elantra? If it doesn't have one what causes the alram, dome light, radio and clock to not work all at once? I check all the fuses inside the car (to the left of the steering weel under the storage bucket) and under the hood and all are in good condition. From reading I thought it sounded like the Etacs but I don't know what it is or where to find it!
Thanks Ben |
RE: Where is the ETACS on a 2005 Hyundai Elantra?
Where is the ETACS on a 2005 Hyundai Elantra? 1.Disconnect the negative (-) battery terminal.[/align] 2.Remove the 2 screws(A) holding the instrument facia panel.[/align] http://www.hmaservice.com/data/Passe...G/etke870a.gif 3.Remove the ash tray then remove the 2 screws(A) holding the instrument facia panel.[/align] http://www.hmaservice.com/data/Passe...G/etke870b.gif 4.Remove the instrument facia panel.[/align] Remove the air conditioner switch panel(A) after removing 4 screws.[/align] http://www.hmaservice.com/data/Passe...G/etke870d.gif 5.Remove the ETACS module (A) after removing 2 bolts.[/align] http://www.hmaservice.com/data/Passe...G/etkd005r.gif I check all the fuses inside the car (to the left of the steering weel under the storage bucket) and under the hood and all are in good condition. |
Did this fix the problem? My girlfriend's 2005 elantra just did this. I swapped the fuses between nthis and a working system and nothing changed, suggesting the fuse was not at fault.
