wiring loom for towing
Hi All New to this Forum but I think I'm going to enjoy it. Can anyone tell me please,is the wiring loom which you hook up to for your 7 pin towing plug located behind the rear of the nearside back panel in the Sante.If so does anyone know how you remove the said panel.Many Thanks look forward to replys.The Honeymonster...
RE: wiring loom for towing
Is your sante fe equipped with a towing package? The towing kit must be wired in if it is not from factory with tow package.
The towing package was already fitted when I bought the vehicle.The problem is intermittent,so I just need to know how to remove the rear facia as I believe this is where the wiring loom has been spliced into.Any information on how to remove this panel would be much appreciated,many thanks ,The Honeymonster...
