01 hyundai accent 87.000 mi auto
Old Jan 15, 2016 | 03:03 PM
ladagosta's Avatar
Default 01 hyundai accent 87.000 mi auto
i purchased this car as a back up come to find out i can not safely drive at night when you start it sometimes it will not shift into gear the headlights, wipers, radio, dash lights will not turn on nor will it shift I found that slamming the doors will finally allow me to shift and the power will then operate all the above items that will not function as a result of the shifter not being able to shift i was told it is most likely a short or relay somewhere I am leaning now towards it being a defective shift control lock up solenoid would anyone confirm or deny this as being a possible cause for the issue more recently the past couple of days i am having issues with removing the key it gets stuck and will not turn to off position only turns to acc position and i can not get it out which now leads me to think it may be an ignition switch gone bad.. would this also cause the other issues posted here or are these separate issues thansk in advance
Old Jan 19, 2016 | 01:34 AM
avisitor's Avatar
Don't know for sure.
Have seen where the nuts loosen on the shift cable and then the gear selection doesn't work properly
When you can't get the gear selector into park then the key will not turn to the off position and the key will not come out
As for the head lights and dash and radio, it could be a short somewhere or loose wire
I am no expert. But, check the fuses first and look around for wires that are near anything metal
Tap on the multi-function switch (stalk switch or headlight switch) to see if the lights will come back on
Old Jan 20, 2016 | 12:56 PM
WholesaleHyundaiParts's Avatar
Former Site Vendor
Default This may be something to look at...
AUTOMATIC TRANSAXLE RANGE SWITCH DIAGNOSTIC TROUBLE CODES P0705, P0707, P0708
DESCRIPTION:
An improperly functioning range switch may result in the following conditions:
  • <li class="ITEM">Diagnostic trouble codes:
    • P0705 - Range switch signal incorrect
      P0707 - Range switch - open circuit P0708 - Range switch - short circuit or multiple inputs
  • MIL (Malfunction Indicator Light) illuminated
  • Harsh P-D or P-R engagement shock
REPAIR PROCEDURE:
  1. <li class="ITEM">Check for DTC in both the Engine and Automatic Transaxle menus. If any of the above DTCs are found, go to Step 2.
    <li class="ITEM"> Disconnect the connectors to the range switch and the TCM. Check for bent pins or pins not fully inserted into the connector. Repair as necessary. If no problems are found, go to Step 3.
    <li class="ITEM"> Follow the repair procedure shown below:
    DTC
    REPAIR PROCEDURE
    P0705
    Replace range switch
    P0707
    P0708
  2. Drive the vehicle for at least two key-on to key-off driving cycles using the shift lever to select L, 2, 3, D and R. If the DTC does not reset, return the vehicle to the customer. If the DTC returns, go to Step 5.
  3. Repair or replace the wiring harness between the TCM and the range switch.
PARTS INFORMATION:
MODEL
PROD. DATE
PART NUMBER
PART NAME
1999-2001 Sonata
980914-
42700-39050
Range Switch
2001 Elantra
000701-
2001 Santa Fe
000701-
2001 XG300
000701-
1997-2001 Accent
970501-
45956-28010
1996-2000 Elantra
951117/000630
1997-2001 Tiburon
960701/010630
1995-1997 Accent
940901/970201
45956-22600
WARRANTY INFORMATION:
MODEL
OPERATION
OP CODE
OP TIME
OP QTY
NATURE CODE
CAUSE CODE
1999-2001 Sonata
42700R00
0.4
*N69
**C15
2001 Elantra
2001 XG300
2001 Santa Fe
0.6
All
Scan tool operation
42700RP0
0.3
MODEL
OPERATION
OP CODE
OP TIME
OP QTY
NATURE CODE
CAUSE CODE
1995-2001 Accent
Replace inhibitor switch
45900R00
0.5
*N69
**C15
1996-2000 Elantra
45900R00
1997-2001 Tiburon
0.6
All
Scan tool operation
42700RP0
0.3
*N69: Warning light on
**C15: Poor contact and short, open circuit
Old Jan 20, 2016 | 12:57 PM
Former Site Vendor
Default This as well...
AUTOMATIC TRANSAXLE HARSH OR DELAYED PARK-REVERSE OR PARK-DRIVE ENGAGEMENT
DESCRIPTION:
If you are servicing a transaxle for harsh or delayed engagement during the Park to Reverse or Park to Drive shift, compare the vehicle with another vehicle of the same year and model. If the engagement shock or delay is more noticeable than other vehicles, follow the repair procedure shown below:
REPAIR PROCEDURE:
  • Check the ATF level when the engine is idling in "N" according to TSB 01-40-013. Adjust the ATF level as needed.
  • Check that idle speed is within specification. If not, inspect the Idle Speed Actuator according to the appropriate shop manual, Fuel System Section.
  • Check the engine and transaxle mounting brackets and roll support brackets for broken or deteriorated mounts. If necessary, replace the mounts.
  • Attach the Hi-Scan Pro and check for Diagnostic Trouble Codes in both the "ENGINE" and "AUTOMATIC TRANSAXLE" menu. If DTCs are found, repair according to the appropriate TSB or shop manual.
  • Attach the Hi-Scan Pro and select "HYUNDAI VEHICLE DIAGNOSIS" menu, "AUTOMATIC TRANSAXLE" menu, "CURRENT DATA" menu and "FLUID TEMPERATURE SENSOR". Confirm the oil temperature sensor operates correctly as shown below. If not, replace the oil temperature sensor.ATF TEMPERATURE
    HI-SCAN READOUT
    ATF cold
    Same as outside temperature
    ATF at normal operating temperature
    (158-212ðF, 70-100ðC)
A. HARSH OR DELAYED PARK-REVERSE ENGAGEMENT:
Select "PCSV-A" and "PCSV-B".
NOTE
Prior to 6/1/99 production, select "PCSV".
Confirm the TCM adjusts the duty during the P-R shift for the PCSV-A and PCSV-B as shown. If not, replace the TCM.
Toggle the left and right keys to measure the start and end of the shift, then subtract the two numbers. If the P-R shift requires:
B. HARSH OR DELAYED PARK-DRIVE ENGAGEMENT:
NOTE
Confirm the TCM adjusts the duty during the P-D shift for the PCSV-A and PCSV-B as shown. If not, replace the TCM.
Toggle the left and right keys to measure the start and end of the shift, then subtract the two numbers. If the P-D or N-D shift requires:
    WARRANTY INFORMATION - (TCM DIAGNOSIS):
    MODEL
    OP CODE
    OPERATION
    CAUSAL P/N
    OP. TIME
    OP. QTY
    NATURE CODE
    CAUSE CODE
    1996-2002 Accent
    95440RP0
    Scan Tool Operation
    See Parts Catalogue for applicable TCM
    0.4
    *N26
    **C15
    1996-2000 Elantra
    1997-2001 Tiburon
    *N26: Abnormal shift
    **C15: Poor Contact And Short, Open Circuit
    Old Jan 20, 2016 | 01:26 PM
    Former Site Vendor
    I do not see any TSB's related to the electrical issues so I would have to suggest having that diagnosed by an electrical specialist. If it does end up needing a range/inhibitor switch we have one available here: SWITCH - INHIBITOR made by Hyundai. #4595628010
    Old Jan 31, 2016 | 12:06 AM
    livelearnfix's Avatar
    Arrow Look in the right place.
    Start with looking at this. Open the glove box. Empty out what you have in there. On each side there is a clip. pull out the clip on the left first, then the right. You will then be able to drop the glove box down. On the right side there is a bunch of wires that clip into a little box. Make sure that is plugged in. Make sure the bracket for the box is secured properly with the black wires behind the bracket. those are ground wires. The transmission range sensor can be used to adjust the shifter position if it does not go into park properly.
    robinl
    Jul 17, 2019 09:23 PM
    NovaResource
    Aug 26, 2011 06:58 AM
    mbm
    Nov 6, 2010 08:25 AM
    jspain
    Apr 7, 2006 04:19 PM
