05 Accent-p0503/p0502 vehicle speed sensor codes
Old Apr 19, 2016 | 11:26 PM
Joe Flynn's Avatar
Default 05 Accent-p0503/p0502 vehicle speed sensor codes
The check engine light came on in my daughters '05 Accent today. I put my code reader on it and it came up with "vehicle speed sensor A intermittent...." After a bit of research I finally found the sensor and replaced it. That did not fix the issue. If anyone has an idea of the next trouble shooting steps to determine where the problem lies I would greatly appreciate the assistance. I have seen a couple of things that suggest that I should replace the ECM, which I am willing to do, however if there is something else that could cause the problem I would prefer to exhaust all possibilities first.
I should note that the code read p0503 at first. I cleared the code, drove around the block, hooked the reader up again and it read p0502. So it seems as if there is a voltage reading issue somewhere, but I have no clue where.
Thank you in advance for taking the time to read this.
Old Apr 20, 2016 | 09:27 PM
avisitor's Avatar
Circuit low and/or intermittent may mean that the wiring is faulty.
Check to see if powers and grounds are present at the sensor
Check electrical schematic to see if any other sensor is on that supply circuit that may be pulling voltage down.
A visual inspection of the wires especially when they go near metal or exhaust pipes??
Old Apr 20, 2016 | 11:37 PM
Joe Flynn's Avatar
I was thinking that there may be an issue with a wiring harness or something along those lines. I will spend the day Saturday tracing and chasing and let you know what/if I find anything.
Thanks for responding
fvela12
Jun 2, 2015 11:21 PM
elkarshofy
Jan 10, 2011 03:40 PM
jdb9920
Jul 30, 2009 08:57 PM
all_atv
May 30, 2008 05:58 PM
seiken
Feb 18, 2008 09:00 PM
