10 accent hatchback: remove the stereo!??!
How do I remove the stereo of my 10 accent hatchback sport GL?? is it the same as the 09 model? I'm having a lot of problems..I got as far as disconnecting the battery negative and that's as far as i got, i couldn't get ANYTHING out.
Yes, it's the same as the 2009
1.Disconnect the negative (-) battery terminal. 2.Remove the center facia upper panel (A). http://www.hmaservice.com/data/Passe...G/utng021f.gif 3.Remove the connectors of digital clock and hazard switch (B). 4.Remove the mounting screws then remove the audio unit (A). http://www.hmaservice.com/data/Passe...G/utng021g.gif 5.Installation is the reverse of removal. |
