100k mileage maintenance?
I have a 2005 Hyundai Accent. I've kept up with a lot of the normal maintenance since I bought it (new), but now that it's got 129k miles on it, I'm wondering what I should be looking for in terms of preventative maintenance. I'm due for another timing belt so I'm thinking if there are things to replace/check out, I should get them done all at once. Any advice/suggestions? Thanks in advance.
Just follow the same plan every 30,000 miles. What you did at 30K is what you do at 90K and 150K. What you did at 60K is what you do at 120K and 180K.
I guess I'm just worried I'm over-looking something, like I should be checking wheel bearings or something like that.
The wheel bearings are sealed from the factory and can't be checked.
My best advice is to go by what the user manual says, not what the dealer or some other mechanic suggests. |
