-   -   14 Inch Wheel Option (https://www.hyundaiforum.com/forum/hyundai-accent-16/14-inch-wheel-option-1463/)
Tom Jul 11, 2006 12:05 PM
My Accent owner's manual identifies a 14 inch option for my 2002 Accent (using tire size 185/60 HR14). Has anyone stepped up to the 14 inch wheels from the stock 13's? What, if anything, was necessary in recalibrating the speedometer to accomodate the larger diameter?
What other adjustments/accomodations are necessary that I haven't mentioned?
Thanks.
cofreth Jul 11, 2006 12:26 PM
RE: 14 Inch Wheel Option
Me using 195/50/15
Accent036 Jul 11, 2006 02:43 PM
i ride 16" inch rims + tires 195/45/r16 i did not change anything to my gauges
and my plan is to fit 17" or mabey 18" rims un der my accent
grtz.
Roy
cofreth Jul 12, 2006 11:44 AM
ORIGINAL: Accent036
grtz.
Roy
Guess 17" is the max for Accent, but then again your FC will be damn high
cslsxpistol Jul 13, 2006 04:57 PM
i have 16" also
AcCenT mAn Jul 14, 2006 04:13 PM
With the 16" you guys rubing the tires alot i went with 15x6.5
Js accent gsi Aug 1, 2006 03:28 PM
hey man i have an 2002 gsi and it has factory 14 inch rims.
try going with the tire size 185/65/r14 that is what i am riding on mime for tire size
i am looking into putting on 15" rims with 165/45/r15 tire size
sameoldd5 Aug 1, 2006 06:24 PM
well you should be able to go as high as 17' rims...with out having to adjust for your rpm's and speedo. just compare it to your stock size side by side.
