-   -   1996 front brake rotor (https://www.hyundaiforum.com/forum/hyundai-accent-16/1996-front-brake-rotor-8330/)
Stryker May 12, 2010 01:16 AM
What's the best way to remove the front brake rotor from a 1996 Hyundai Accent? Am I assuming correctly in that in order to remove the hub nut you need to turn it counter clockwise?
Thanks for your help.
zero_gravity May 12, 2010 11:17 AM
www.hmaservice.com has all the service info.
however its very simple.
-jack car up - use jackstands and wheel chocks. be safe.
-remove tire
-remove brake caliper mounting bolts - NOT the slide pins
-caliper slides right off. might have to push/grunt a little but its not bad.
-get some wire or rope and tie the caliper to the spring to avoid letting it hang.
-rotor pulls right off.
