1996 Hyundai Accent overhearing
I have a 1996 Hyundai Accent that is over heating with NO LEAKS! 😭 we have already changed both parts of the coolant temperature sensor.. and it is still occurring. Please help!!
When the engine is cold, check the coolant level?
Start engine with radiator cap off Watch to see if the fans turn on Turn AC on and see if both fans turn on? Do you see coolant flowing pass in the radiator ? No flow could be due to stuck thermostat or failing water pump If all else is fine then radiator needs to be cleaned and flushed It could be something else but would need more testing |
