2000 Accent Starting Problem!!!
I need some advice for my girlfriends 2000 accent, its an auto and i think 1.4 ltr, started having problems starting and read a bunch of stuff in here and went from there but still no luck, the car wouldnt start, battery is good, changed the plugs, wires, and coil pack. started and ran, no check engine light is on, then once agian it wouldnt start. replaced fuel pump and fuel filter, started and ran.no check engine light. went out this morning to check and wouldnt start. just keeps turning but no starting, Can someome please advise?? we cant afford much right now so the chepest fix would be great!!! Thanks!!!
Rent an OBDII tool from Autozone and scan for codes
It could have codes even though the check engine light isn't on. The tool is free to rent, you only have to leave a deposit. |
sounds like you've hit everything but the fuel injectors! you should have the pressure tested
