2001 Accent signal lights not working
None of the signal lights front or back are working on my 2001 Accent. I tried changing fuses but nothing happened. Please help!!
RE: 2001 Accent signal lights not working
I'd say it's likely that your indicator/signal light relay is blown. Easily fixed. A new relay should only cost you around 10 euro/dollars (depending where in the world you are:D)
Don't ask me where the relay in question is located on an accent though[&:] |
Now that I think of it the relay is probably in the fuse box located near the battery in the engine compartment
