-   -   (2002 accent 1.5) water pump pulley removal (cylinder head removal) (https://www.hyundaiforum.com/forum/hyundai-accent-16/2002-accent-1-5-water-pump-pulley-removal-cylinder-head-removal-13531/)
zainecurtis Mar 20, 2013 11:16 PM
im removing and repairing or replacing my cylinder head on my accent. im to the point that i need to remove the coolant pump pulley from all of my research i do not need to remove engine on the 1.5 but i am not able to get access to the bolts on the pulley due to the half to one inch gap inbetween the side wall.. what can you guys recommend that i do in order to remove this pulley and also if you have done this before what other issues may i run into that you have advice on. thanks for your time!!
zainecurtis Apr 5, 2013 02:34 AM
any help or info??
anyone
