-   -   2004 Accent Transmission (https://www.hyundaiforum.com/forum/hyundai-accent-16/2004-accent-transmission-11502/)
teddybear Sep 22, 2011 03:48 PM
New member, I'm looking for info and links to rebuilding the 2004 Accent Transmission. Any help is greatly appreciated.
Teddybear
NovaResource Sep 22, 2011 04:17 PM
Manual?
Automatic?
teddybear Sep 25, 2011 10:13 AM
2004 Accent Automatic Transmission
Automatic
by the way, the fluid is nearly black, but no signs of metal in the pan. How deep should I go?
Also, it's looking like the whole engine/transmission pack has to come out together. Yes?
Teddybear
ken99 Sep 25, 2011 08:58 PM
How deep should you go? What exactly is wrong with the transmission?
teddybear Sep 26, 2011 12:53 PM
What is wrong with Transmission?
no reverse
when up to operating temp., slams into drive(1st)
will not shift to 2nd, except sometimes at high rpm
i do not know the symtems prior to failure except that it "banged" than would not shift. Father-inlaw drove home (15miles) in 1st gear very slow.
I towed it to my place, drove it around up to 30mph, shifted once or twice. still no reverse.
Thanks Dan
ken99 Sep 26, 2011 09:51 PM
I think it is toast from what you describe. If you insist on a DIY project, I think I'd buy an already rebuilt tranny and torque convertor. Otherwise, I'd find a good transmission mechanic to do the work for you. The guts of these things are quite complicated and usually require a number of special tools that your average person doesn't have. The HMA Service site (Hyundai Service Website) has instructions regarding removal.
teddybear Sep 27, 2011 02:13 PM
I am going to rebuild the trans. With these symtoms, what would be a likely item(relay, pulse generator, valve, etc.) that would have gone bad? Bands are understood. I'll do a total tare down and clean. (I made the mistake of not getting a diagnostic before I started.)
Thanks, Dan
ken99 Sep 27, 2011 09:07 PM
It could be most any of those items. Be mindful of the ball bearings that can roll out of nowhere during disassembly.
Good luck.
