2005 accent factory radio
Need to know how to remove it.
What all needs to come apart thanks in advance |
RE: 2005 accent factory radio
2005 > G 1.5 SOHC > Body Electrical System
REMOVAL AND INSTALLATION 1. Disconnect the negative battery terminal. 2. Remove the glove box. http://www.hmaservice.com/data/Passe...G/etda015b.gif 3. Disconnect the 2 heater side control cables under the lower crashpad and one blower side control cable under the glove box. http://www.hmaservice.com/data/Passe...G/kqdd020b.gif 4. Loosen the screws and remove the center facia panel. http://www.hmaservice.com/data/Passe...G/etda015c.gif 5. Remove the audio mounting screws (4EA) and the audio system. http://www.hmaservice.com/data/Passe...G/etda015d.gif 6. Installation is the reverse of removal. |
wow.
you are the best.... thank you very much |
thanks for this i got a tape jammed in there!!
any suggestions for what to replace it with ? or maybe if I can get this tape out I can just do it myself! |
