2005 fuel filter location
Looking for the fuel filter on a 2005 Hyundai Accent. I've looked under the back seat and there is not one there. I even pulled the fuel pump out of the tank thinking it might be with the fuel pump, but I don't see it. I've looked all up and down the underside of the car (where they normally are). I'm stumped. Do some of these cars not have a fuel filter?
Thanks! |
RE: 2005 fuel filter location
It's back in the car now, but I don't think it looked quite like that...although similar. Mine had a large fuel float attached to it & had a pre screen at the pick-up. It did have a similar plastic casing that you had to undo clips to get it apart. I don't remember seeing anything that looked like that fuel filter, but I'm not sure I would have guessed it was the filter. Autozone supplied me with a traditional looking in-line fuel filter.
I had a hard time finding my filter in my '99 Elantra. I finally found it under the brake booster bolted to the firewall, behind a plastic cover. I had to take out the stock intake junk to see it.
Looking for the fuel filter on a 2005 Hyundai Accent. |
Thanks for the link! That looks more like the fuel pump housing that I have. If that is the fuel filter, how do I get a new one. All the local autoparts stores want to give me an in-line filter. Do I need to go to a steeler?
part Number: 043-1040 http://www.autozone.com/R,2267398/ve...ductDetail.htm |
If that is the fuel filter, how do I get a new one. |
