2006 accent Fuel pump doesnt pump
Hello,
I have a problem with my 2006 accent. The fuel pump doesnt do anything. there is no electricity coming on the pump. Just on the thing which checks the hight of the fuel.
I want to check all the wiring. I took out the relais of the fuel pump and the car gives 12v to the relais. I changed the relais with the one of the airco ... to see if this was helping ... but no. The cable ending at the pump is dark green, but this one doesnt have power.
Normally when you turn the key you hear the pump a few seconds. But nothing happends in mine.
Does anyone know how the wiring is of the 2006 accent? Or does anyone recognize my problem? Or any other advices?
Thanks!
Thanks!
hi, thanks for your reply!
no i couldnt see a fuse ... not under the steering wheel and also not in the fusebox under the hood.
Do you know the place of the fuse?
Does hyundai accents also have something like an accident switch, which cuts off the fuel pump in case of an accident.
2loud2k2xd
Mar 18, 2006 07:38 PM
