2013 Accent P0016, P0017, P0326, P0366
Accent throws up above errors. Also battery light comes on while driving if radio, fan on high.
So far on advice from local mechanic replaced: timing chain Cam phazors Crank sensor cam sensors oil control valve ECM/ECU He has checked all the wiring, verified alt is charging and has no open or short to ecm. (also verified timing is correct). His last advice was ECM but after replacement I have the exact same problems! Any and all help is greatly appreciated! |
