'97 Accent Gearbox help
Hi,
I'm another newbie. I hope that someone can help me. I have a 1997 Accent 1.3Si (UK). Am having gearbox trouble. It started with tight selection of gears - particularly 2nd & 4th. Has to drive 3miles home stuck in 2nd gear. With help off my wife, she wiggled the gear stick & selected gears (without engine running). Found them stiff to select. I stuck my head under the bonnet, looking for trouble. Could not see anything broken. Suddenly the gear stick became loose. (inside the car) . The selector rods mounted on top of the gerabox did not move. If I pushed the rods toward the bulkhead my wife could select gears. But it would then stick in that gear. Does any one have a clue what it wrong? No stupid replies please!! |
RE: '97 Accent Gearbox help
Hi New Member:
You might want to move this to the General Tech Area where it will get better attention...sorry I cant help you with it myself... WheelBroker1 [sm=americanasmiley.gif] |
@wheelbroker1 thanks.
Ill do that |
| All times are GMT -5. The time now is 03:28 AM. |
