99 2 door coupe Front Hub/Rotor/Wheel Bearing installation question
Ok so I have trolled all the forumns and found out how to pull the hub and change the rotor. I did all this yesterday.
My hubs came off and wheel bearings and sleeve still attached to them. I did not take apart the knuckle and bearings and have them re-pressed in. I re packed the bearing with grease then, I re-assembled and drove the hub back on by using the wheel nut. so my question is: will that be sufficient or DO I HAVE TO dissasemble the bearing and knuckle and have the bearings re-pressed? please if anyone has done this let me know if it worked for you. everything went back together nice and smooth but I heard I can burn up my bearings by doing it that way. |
I beleive that you have taper roller style bearings, and possibly an oil seal came off with it.
In general, I would prefer to assemble new-lubed bearings and new seals to the knuckle, then press the hub through the asembled knuckle/bearings as an assembly. Bearings can be had at your local bearing supply/NAPA using the industry number on the bearing and race for a good bit less than dealer... my sis is a service rep with TIMKEN, so I have line inexpensive bearings and seals.. |
yes they are tapered. and yes there was a seal in front of them, all were in good condition.
I understand new bearing and pressing would be best but since the job is done. Is it ok I put them back on by using the axle nut without the washer, then I checked them to make sure they were on good and tight and they were.. Just hopping I didn't shortcut myself into trouble later. |
| All times are GMT -5. The time now is 09:46 AM. |
