'99 Accent Exhaust Manifold
I have a cracked exhaust manifold and my mechanic took out the cracked one and tried to replace it with a '98 and it did not fit.
Are the manifolds from the 1999-2002 Accent compatible with each other? Is it best to find a junk yard and just take one out of there? Or should I find a welder to repair it? A new part is over $500 and I know I can find a used one somewhere cheaper... way cheaper. Please help so I know which models to seek to take this part out... Thanks! |
Yes, the 1998 manifold is significantly different from the '99. You could get one from the junkyard, but then there's the problems with the CAT too. A lot of times the CAT bolts are all rusted up, or the CAT itself is toast.
The 99 manifolds had this problem with cracking, so I wouldn't get one from the junkyard. The Elantra RD model was only made until 2000, so that means you'd have to find one from '99 or '00. I wouldn't expect the Accent manifold to fit. I'd buy this manifold + CAT from eBay for around $190: http://cgi.ebay.com/ebaymotors/2-0-H...spagenameZWDVW |
Originally Posted by troyboi
(Post 22150)
http://www.hmaservice.com/files/331/...5-01-001-1.pdf |
| All times are GMT -5. The time now is 04:06 AM. |
