Accent 2008
i have had a boggy problem for months and cant find the problem i changed the injectors the coils the plugs cleaned all the sensors and no change at all at low RPM like under 3000 when its cold it sounds like it wants to stall when hot its boggy from time to time like one min its ok then 2 minutes later its boggy
Is the check engine light on? if so what are the codes?
Even if you have no codes you can do the following:
Make sure all electrical connections are clean. Check the battery cables and don't forget the ground connections.
Have the battery and the alternator tested. A bad alternator can cause all kinds of wonky things.
Check for vacuum leaks. Cracks in hoses can open and close when the engine moves a little.
