-   -   Accent GLS 2006 1.6L -trouble starting the car at gas station every refuel (https://www.hyundaiforum.com/forum/hyundai-accent-16/accent-gls-2006-1-6l-trouble-starting-car-gas-station-every-refuel-11192/)
vargasgw Jul 20, 2011 02:46 PM
Only happens at the gas station, in other times has no engine start problems. It happens every time I put gas in the tank. I will appreciate any help on find out a solution. Thanks
Abstract Hero Jul 20, 2011 03:15 PM
Does it turn over?
NovaResource Jul 21, 2011 07:59 AM
The purge valve is sticking open. Have it changed. More info:
https://www.hyundaiforum.com/forum/h...problem-10285/
https://www.hyundaiforum.com/forum/h...fueling-11137/
vargasgw Jul 21, 2011 08:54 PM
Thanks
I appreciate both responses. I will get purge valve change. Thanks
vargasgw Jul 21, 2011 08:57 PM
Yes it turns over but acts like it isnt getting any fuel
vargasgw Aug 3, 2011 10:57 PM
2006 Hyundai Accent GLS 1.6L Fuel System too Lean
Does anyone have Fuel System Too Lean as result from diagnostic? I will appreciate your help. Thanks
vargasgw Aug 7, 2011 09:14 PM
Dear NovaResource,
which purge valve are you recommending to change? PCSV or canister vapor vent valve that it also calls as purge valve. do you know part #? Thanks
NovaResource Aug 8, 2011 08:00 AM
The evap canister
vargasgw Aug 13, 2011 08:46 AM
I replaced valve and I went to gas station to test it and still got the same problem. Does anyone have more ideas on how to fix it. Only happen when I put gas. Thanks
Houseworth_t Aug 23, 2011 12:16 AM
The purge control valve was the problem on mine. Try over filling the tank a few handle pulls till the filler lever on the gas pump clicks. May send some fuel through to unstick something. Besides one or twice wont hurt just don't over fill everytime.
