Broken AC Vent ?
Wanted to share an easy and cheap fix for broken air vents. The vent usually does not break , but the parts that make it work break or become loose or fall off . The biggest issue is the air vent tab , the plastic piece that a driver uses to point the air flow in the car. We found a simple solution for many Hyundai models on a website called venttabs , www.venttabs.com . Give it a shot , probably save you the $200 that the dealer will charge for a new air vent assembly . Good luck
