Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership to
Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership to get these bulbs replaced?
I just got a fix it ticket in california because one of my break lights was out. When I took my Hyundia Accent to pep boys they couldn't easily replace the light. Do I need to take my Hyundia Accent 07 into the dealership to have them replace the back breaklight? I also need one of the liscence plate bulbs replaced as well. Have any of you guys ever fought a fix it ticket? I plan on fighting this in court. |
RE: Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership
Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership to get these bulbs replaced? Tail Light Fixture: REPLACEMENT 1.Disconnect the negative (-) battery terminal.[/align] 2.Loose the nuts holding the rear combination lamp then disconnect the 6P connector then remove the rear combination lamp.[/align] http://www.hmaservice.com/data/Passe...G/ktnf491l.gif 3.Installation is the reverse of removal.[/align] License Light Fixture: REPLACEMENT 1.Disconnect the negative (-) battery terminal.[/align] 2.Detach the license lamp lens (A) from the trunk lid panel with a flat-tip screwdriver.[/align] http://www.hmaservice.com/data/Passe...G/atie498a.gif 3.Replace the bulb.[/align] 4.Installation is the reverse of removal.[/align] Have any of you guys ever fought a fix it ticket? |
yes i am trying to fight the fix it ticket.... anyone?
| All times are GMT -5. The time now is 08:28 AM. |
