2002 Accent rear bumper cover removal
My daughter's Accent was slightly hit from behind and her rear bumper cover was cracked pretty badly. I'm trying to fiqure out how to get the old one off so I can replace it with a new one. Does anyone have a diagram on the rear bumper assembly, Also a fiqure on how much a new bumper cover will cost her?
RE: 2002 Accent rear bumper cover removal
REMOVAL AND INSTALLATION
1. Remove the transverse trim and luggage rear trim.
2. Loosen the 2 mounting bolts and 2 nuts from the luggage rear trim inner rear bumper cover.
3. Remove the rear combination lamp.
4. Loosen the 3 mounting screws on the mud guard, remove the mud guard, and loosen the rear wheel house inner mounting screw.
5. Loosen the 6 mounting screw on the upper rear bumper cover.
6. After loosening the rear bumper cover inner rail mounting bolts (Left : 2, Right : 2), remove the rear bumper assembly.
7. After loosening 5 mounting screw on the rear bumper cover, disconnect the cover from the rail.
8. Installation is the reverse of removal.
