check engine light
I have a 2005 accent with 26,000 miles a year ago December the car started jerking and the check lught started flashing then it stayed on and car ran fine. I took it to the dealer and they said it was a misfire and could find o problem they reset and it was fine till this last december and te same thing happned again. bak to the dealer same thing, tey reset and it was fine, today it did the same thing started bucking and light started flashing i coasted a ways and the light went off and seemed ok. i stopped for fuel and when i was leavig it started bucking again and the ight stayed on this time. i had a meeting to go to and drove there and car was fine but lght on. service dept is not open today so I will call Monday for appointment. has anyone had this problem or possibly know what it might be? any help will be appreciated. I love the car and othe than thi have had no problems.
Thanks Dave |
RE: check engine light
Almost impossible to tell, could be lots of thing. You need to get the code read-out yourself, then we can give you an idea on this forum. If you take it to Autozone, they will do a free code scan for you and give you the codes.
I had the codes checked and it is going into the dealer in the morning. the codes are p0300 and p0303 any info before i head to the dealer would be helpful
thanks. Dave |
Probably a bad spark plug. Start there first. Cylinder #3.
http://www.obd-codes.com/p0300 http://www.obd-codes.com/p0303 |
Just got back from the dealer they swapped #3 cyl plug with cyl #2
swapped cyl # 3 fuel inj with cyl # 1 reset light said to drive it and when it happens again they can narrow it down. THanks for your help with all the information Dave |
That's interesting! Yes, for sure that will help. Good mechanic.
Hi Dave – Had exactly the same symptoms as you with my 1.3 GLi Accent although I changed spark plugs, ignition leads, but was only cured when the one of the two electronic ignition modules was changed.
The engine check light was reset by disconnecting the battery for a few mins. Hope above helps – Regards Terry |
any new info on the problem? i have a similar situation. Just looking for a little insight b4 i changed the coil pack
Thanks Terry for the info. Car has been fine so far they have left the service ticket open so if and when it happens again i will tell them about your suggestion.
Thanks Dave |
i have a 2000 accent and in getting the same thing ive changed my plugs wires and coil and cam sensor and i still get bucking im beginning to wonder if it isnt my fuel pump and or relay weird thing is the problem only occurs when its driving at idle it runs perfect no shakes or stumbles which would be easy to feel since i got poly front and rear mounts and i filled the voids of a stock tranny mount with poly so nothing moves until im driving and it wants to buck down the street.
