Check Engine light, no code
HI, just purchased a 2001 Accent GSI (1.6L/std trans/no air). After about a week of driving it, the MIL came on. I scanned it and it shows no codes. I d/c the battery cable to eliminate the light, but it came back on after a few days of driving, again no code comes up on my scanner, and the scan says MIL off.
Any clues out there? cheers |
RE: Check Engine light, no code
possible short to ground in the intrument cluster. u a tech?
I had this problem. First, check to see if there is a hole or leak in the muffler. Next, check for a hole or leak in the flex pipe in the muffler assembly. This is a heavy braided metal pipe. The oxygen sensor is attached to it. It is the sensor which is causing the engine light to go on. A hole in the muffler can be repaired with muffler weld paste or tape. A hole in the flex pipe - it needs to be replaced. Just the flex pipe, not the whole muffler assembly.
Hope this helps. |
thanks for the hint, but no holes are present
cheers |
