check engine light P2069?
hey guys, i did a search for "p2069" and nothing came up? thats the reason why i started this post, believe me i always search before i ask ;)
my sister-in-law has a 2004 accent, she came home from work today and got a check engine light, she got it scanned and came up with P2069? any idea what the cause of this code is? any help and guidance is greatly appreciated danny |
I don't see that code listed for a 2004 Accent but here's what the manual says for a Genesis Coupe.
P2069 = Fuel Level Sensor "B" Circuit Intermittent The Fuel Level Sensor(FLS) measures the fuel level in fuel tank and its information is used to supply the ECM with information regarding the monitoring condition of the EVAP canister purge system for leak detection. If the fuel level sensor is monitored for high or low stuck or difference between voltage of fuel level sensor and voltage deviation of fuel level sensor is exceeds limited value while driving, this is interpreted by the ECM as a fault. Many malfunctions in the electrical system are caused by poor harness(es) and terminals. Faults can also be caused by interference from other electrical systems, and mechanical or chemical damage. Thoroughly check connectors for looseness, poor connection, bending, corrosion, contamination, deterioration, or damage. https://www.hyundaitechinfo.com/data...sbkfl9217d.gif https://www.hyundaitechinfo.com/data...sbkfl9622n.gif |
