Code p0342
Have 2001 Accent check engine light on code p0342.
I changed timing belt cam sensor and crank sensor. Yes timing belt is on correct check it 4 times and had garage check it. Have 12v signal at cam sensor have ground signal and wire back to pcm is not shorted or grounded. This leads me to believe i have a bad PCM. Light was never on until I changed timing belt. Also used after market parts??? If any one has any suggestions before I go waste more time and money on PCM please let me know :confused: |
