Collant drain plugs on engine location?
I cannot seem to find coolant drain plugs on short block underneath i know every engine has it so can someone assist i want to do full drain.
Need exact location better with a picture. P.S. Tried getting off heater pipes however i cannot manage it safely its too tight. |
99 times out of 100, that plug is stuck on tight and no amount of force will get it out without damaging the engine block.
But, I wish you luck to find it and remove it. |
I just looked through all diagrams for the 99 Accent and I could not find the plug you are looking for. If you want the best flush I would suggest using a coolant flush machine.
