Crankshaft bolt on 02 Accent
I can not seem to break the crankshaft bolt loose on my 2002 Hyundai Accent...tried impact wrench (3/8 hose about 150 lbs pressure and nothing) then tried breaker bar and engine wanted to turn any suggestions besides the old starter breaker bar trick
Is there a way to hold crakshaft pulley and use breaker bar on bolt? with out damage to pulley? Or do I need bigger impact? Also can I lock the timing gears in place so I can timing belt on right? One other question can water pump be changed with timing still on? THANKS |
