Dash Brake Light on?
First thing this morning the "Dash Brake LIght" the same one as the e-brake, came on? I have checked the level of the brake fluid and it appears to be okay, When the brake pedal is depressed I hear what seems to be a louder than normal relay noise coming from the glove box area? Brake stopping and feel of the pedal has not changed and all three (3) brake lights are working? Any feed back would be great. Thank You https://www.hyundaiforum.com/micons/m8.gif
RE: Dash Brake Light on?
There might be an electrical switch attached to the e-brake handle,down inside the plastic housing. If that is sticking or a bad electrical connection, that could cause the light to remain on. Hope this helps.
Bizarre. This exact same thing just happened to me this morning, leading to my first post on this board...
