difficulty shifting into reverse
Old May 30, 2006 | 12:08 AM
ddown's Avatar
Default difficulty shifting into reverse
anyone with a 2006 accent with a manual transmission have a really hard time getting it into reverse when the car is cold???
Old May 30, 2006 | 02:07 AM
hyundai tech's Avatar
Default RE: difficulty shifting into reverse
Could be incorrect syncro clearance.You would probably want to drop at dealer overnight so they can feel it cold.I would let them take it from there.
Old May 31, 2006 | 01:43 PM
ddown's Avatar
thank you. If I shift through a few gears and engage/disengage the clutch a few times I can usually force it in to reverse. Could much damage have been done already to the transmission internals if this is the case?
Old Jun 1, 2006 | 01:57 AM
Either way if it is inside transmission it will have to be dismantled and assesed from that point to see what parts are needed.Make a date with your dealer.
Old Jun 20, 2006 | 03:18 AM
stokelife's Avatar
My friend has a VW and suggested something that worked for me.
When shifting into reverse make sure the car is fully stopped, then sift into 1st then into reverse.
Going into 1st then reverse seems to help.
Old Jun 21, 2006 | 12:04 AM
You should not have to shift to 1st before reverse.Maybe on a vw but an 06 accent should be able to go directly to reverse.
HocusPocus
Feb 26, 2010 08:04 PM
dennisjerde
Oct 16, 2007 01:25 PM
gatorwv
Jun 25, 2007 04:50 AM
Chyvalri
Feb 1, 2007 11:59 AM
SlowAccent
May 24, 2006 02:57 AM
